Cauptain
Contact: ICQ
Excluded List - Action!!!
Sun Nov 04, 2012 11:46 am
A little doubt:
This excluded list only works with the full name ( Adobe3DAndVideoServer.exe) or we can use the reduced mode (ADOBE3~1.EXE)?
Doing this manually is very time consuming and boring.
If use of the dos name, will be much easier.
Tks
Claudio
Re: Excluded List - Action!!!
Mon Nov 05, 2012 12:43 pm
Thanks for your suggestion. You have to type full name of the process. We will see if there's an easier way to add the processes to Action! exclude list list.
sinnfullduck
PC Specification: i7 2600k, radeon 6870, win7
Tue Nov 06, 2012 10:57 pm
What is the Excluded List, I'm not familiar with it?
vivan
Wed Nov 07, 2012 12:00 am
sinnfullduck,
Ghost wrote:possibility to block Action! from monitoring selected applications
http://mirillis.com/en/products/tutoria ... -list.html
PS Vita, Nokia N8
Cauptain
Contact: ICQ
Wed Nov 07, 2012 8:24 am
radi wrote:Thanks for your suggestion. You have to type full name of the process. We will see if there's an easier way to add the processes to Action! exclude list list.
Hi radi,
Thanks for reply, but I I forgot to show because of my suggestion.
See below using a tiny, free and portable software:
Claudio
