Mr_KoKa
PC Specification: Win7 x64 | Phenom II 955 | GTX 285 1GB
Action! and Steam Overaly UI in CS Global Offensive
Sat Dec 01, 2012 10:25 pm
Action! is blocking steam overlay ui :/
When I turn Action! off shift+tab works normally.
GameOverlayUi.log when Acrion! is running:
Code: Select all
Sat Dec 01 22:05:08 2012 UTC - Module file name: C:\Program Files (x86)\Steam\GameOverlayRenderer.dll
Sat Dec 01 22:05:08 2012 UTC - GameID = 730
Sat Dec 01 22:05:09 2012 UTC - System page size: 4096
Sat Dec 01 22:05:09 2012 UTC - Failed loading shell32.dll, not hooking ShellExecute calls
Sat Dec 01 22:05:09 2012 UTC - Hooking SetCursorPos, GetCursorPos, ShowCursor, and SetCursor
Sat Dec 01 22:05:09 2012 UTC - Hooking GetRawInputBuffer calls
Sat Dec 01 22:05:09 2012 UTC - Modules at GameOverlayRenderer.dll attach
Sat Dec 01 22:05:09 2012 UTC - 01: csgo.exe
Sat Dec 01 22:05:09 2012 UTC - 02: ntdll.dll
Sat Dec 01 22:05:09 2012 UTC - 03: kernel32.dll
Sat Dec 01 22:05:09 2012 UTC - 04: KERNELBASE.dll
Sat Dec 01 22:05:09 2012 UTC - 05: USER32.dll
Sat Dec 01 22:05:09 2012 UTC - 06: GDI32.dll
Sat Dec 01 22:05:09 2012 UTC - 07: LPK.dll
Sat Dec 01 22:05:09 2012 UTC - 08: USP10.dll
Sat Dec 01 22:05:09 2012 UTC - 09: msvcrt.dll
Sat Dec 01 22:05:09 2012 UTC - 10: ADVAPI32.dll
Sat Dec 01 22:05:09 2012 UTC - 11: sechost.dll
Sat Dec 01 22:05:09 2012 UTC - 12: RPCRT4.dll
Sat Dec 01 22:05:09 2012 UTC - 13: SspiCli.dll
Sat Dec 01 22:05:09 2012 UTC - 14: CRYPTBASE.dll
Sat Dec 01 22:05:09 2012 UTC - 15: IMM32.DLL
Sat Dec 01 22:05:09 2012 UTC - 16: MSCTF.dll
Sat Dec 01 22:05:09 2012 UTC - 17: GameOverlayRenderer.dll
Sat Dec 01 22:05:09 2012 UTC - 18: ole32.dll
Sat Dec 01 22:05:09 2012 UTC - ----------------------------
Sat Dec 01 22:05:09 2012 UTC - Found GetModuleHandleEx
Sat Dec 01 22:05:09 2012 UTC - Game is using D3D9 or D3D9Ex, preparing to hook.
Sat Dec 01 22:05:09 2012 UTC - hookDirect3DCreate9 called
Sat Dec 01 22:05:09 2012 UTC - Game is using dxgi (dx10/dx11), preparing to hook.
Sat Dec 01 22:05:09 2012 UTC - Game is using ddraw.dll (dx7 or lower)... hooking.
Sat Dec 01 22:05:09 2012 UTC - Game is using opengl32.dll... hooking.
Sat Dec 01 22:05:10 2012 UTC - IWrapIDirect3D9::CreateDevice hook called (type: 1, behavior flags: 56!)
Sat Dec 01 22:05:10 2012 UTC - Unknown opcodes for X86 at 4 bytes: 83 EC 08 53 33 DB 56 57 39 1D F4 B4 A3 69 0F 84
Sat Dec 01 22:05:10 2012 UTC - Unknown opcodes for X86 at 4 bytes: 83 EC 0C 53 33 DB 56 57 39 1D F4 B4 A3 69 0F 84
Sat Dec 01 22:05:30 2012 UTC - GameOverlayRenderer.dll detaching
Re: Action! and Steam Overaly UI in CS Global Offensive
Sun Dec 02, 2012 12:22 am
Could you post similar log when Action! is not running?
Kashimus
PC Specification: windows 7 ultimate x64
Sun Dec 02, 2012 1:18 pm
I dont own cs:go but for me steam overlay works fine,with action, the solution is start the game, with out action running, wait for the game to load check the overlay,if its working alt tab out and start action! it should work(i run steam and action,and ts as administrator,some times in vista/win 7 the overlay dont work if you run it as "normal" user right clikc on the steam,and action compatibility tab and rus as administrator it will always ask before running and need to play yes), for me with this method i can have steam overlay+ts3 overlay+action overlay at the same time(1-steam,2-action,3-ts3 each with alt tabbing out and starting the program, this works only for the first start (all 3) after it the steam overlay is "blocked"but the other 2 is working, (for me the ts3 and action works great), the trick is the starting order,cuz the overlay's "kills/blocks" each other.
Mr_KoKa
Sun Dec 02, 2012 3:14 pm
It's the log when Action! isn't running:
Code: Select all
Sun Dec 02 14:50:31 2012 UTC - Module file name: C:\Program Files (x86)\Steam\GameOverlayRenderer.dll
Sun Dec 02 14:50:31 2012 UTC - GameID = 730
Sun Dec 02 14:50:31 2012 UTC - System page size: 4096
Sun Dec 02 14:50:31 2012 UTC - Failed loading shell32.dll, not hooking ShellExecute calls
Sun Dec 02 14:50:31 2012 UTC - Hooking SetCursorPos, GetCursorPos, ShowCursor, and SetCursor
Sun Dec 02 14:50:31 2012 UTC - Hooking GetRawInputBuffer calls
Sun Dec 02 14:50:31 2012 UTC - Modules at GameOverlayRenderer.dll attach
Sun Dec 02 14:50:31 2012 UTC - 01: csgo.exe
Sun Dec 02 14:50:31 2012 UTC - 02: ntdll.dll
Sun Dec 02 14:50:31 2012 UTC - 03: kernel32.dll
Sun Dec 02 14:50:31 2012 UTC - 04: KERNELBASE.dll
Sun Dec 02 14:50:31 2012 UTC - 05: USER32.dll
Sun Dec 02 14:50:31 2012 UTC - 06: GDI32.dll
Sun Dec 02 14:50:31 2012 UTC - 07: LPK.dll
Sun Dec 02 14:50:31 2012 UTC - 08: USP10.dll
Sun Dec 02 14:50:31 2012 UTC - 09: msvcrt.dll
Sun Dec 02 14:50:31 2012 UTC - 10: ADVAPI32.dll
Sun Dec 02 14:50:31 2012 UTC - 11: sechost.dll
Sun Dec 02 14:50:31 2012 UTC - 12: RPCRT4.dll
Sun Dec 02 14:50:31 2012 UTC - 13: SspiCli.dll
Sun Dec 02 14:50:31 2012 UTC - 14: CRYPTBASE.dll
Sun Dec 02 14:50:31 2012 UTC - 15: IMM32.DLL
Sun Dec 02 14:50:31 2012 UTC - 16: MSCTF.dll
Sun Dec 02 14:50:31 2012 UTC - 17: GameOverlayRenderer.dll
Sun Dec 02 14:50:31 2012 UTC - 18: ole32.dll
Sun Dec 02 14:50:31 2012 UTC - ----------------------------
Sun Dec 02 14:50:31 2012 UTC - Found GetModuleHandleEx
Sun Dec 02 14:50:31 2012 UTC - Game is using D3D9 or D3D9Ex, preparing to hook.
Sun Dec 02 14:50:31 2012 UTC - hookDirect3DCreate9 called
Sun Dec 02 14:50:32 2012 UTC - Game is using dxgi (dx10/dx11), preparing to hook.
Sun Dec 02 14:50:32 2012 UTC - Game is using ddraw.dll (dx7 or lower)... hooking.
Sun Dec 02 14:50:32 2012 UTC - Game is using opengl32.dll... hooking.
Sun Dec 02 14:50:32 2012 UTC - IWrapIDirect3D9::CreateDevice hook called (type: 1, behavior flags: 56!)
Sun Dec 02 14:50:33 2012 UTC - Trying to setup input hook...
Sun Dec 02 14:50:33 2012 UTC - Set input hook...
Sun Dec 02 14:51:08 2012 UTC - Found a hooked function in now unloaded module, removing from map.
Sun Dec 02 14:51:08 2012 UTC - GameOverlayRenderer.dll detaching
Sun Dec 02 14:51:08 2012 UTC - Detaching input hook...
I tried to run Action! as administrator, then both, Action! and Steam, but that doesnt help, Steam even said that I'm shouldn't run it in any compatibility mode, but only after first start after checking "run as administrator".
Running Action! after game start works fine in this case, but in some cases running Action! after game start doesn't work, and there are no Action! Hud displayed and recording doesn't work.
