Spiderm@n
PC Specification: i7-3770K, GTX670-DC2-4GD, Windows 8
Action, Windows 8 and QuickSync
Wed Jan 02, 2013 5:24 pm
I have a "big" problem. I can't make Action! work with QuickSync on Windows 8 x64. When I set Action! to work using the HD 4000 in the CPU, that has QuickSync the program opens and in few seconds crashes. If I set it in D-mode, or turn off the settings in VirtuMVP, it uses my GTX-670 card and works normally, but I can't record in 1080 MP4, because QuickSync is not available then.
P.S. Whe the program crashes, it leaves to logs in the event viewer, one error and one information.
The Error one:
Code: Select all
- <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
- <System>
  <Provider Name="Application Error" />
  <EventID Qualifiers="0">1000</EventID>
  <Level>2</Level>
  <Task>100</Task>
  <Keywords>0x80000000000000</Keywords>
  <TimeCreated SystemTime="2013-01-02T17:06:01.000000000Z" />
  <EventRecordID>15201</EventRecordID>
  <Channel>Application</Channel>
  <Computer>Vladimir</Computer>
  <Security />
  </System>
- <EventData>
  <Data>Action_x86.bin</Data>
  <Data>0.0.0.0</Data>
  <Data>50817889</Data>
  <Data>KERNELBASE.dll</Data>
  <Data>6.2.9200.16451</Data>
  <Data>50988950</Data>
  <Data>80000003</Data>
  <Data>00089bfc</Data>
  <Data>5f6c</Data>
  <Data>01cde90b70b6655e</Data>
  <Data>C:\Utilities\Tools\Mirillis\Action!\Action_x86.bin</Data>
  <Data>C:\Windows\SYSTEM32\KERNELBASE.dll</Data>
  <Data>aeb7769d-54fe-11e2-bea7-c86000ccb596</Data>
  <Data />
  <Data />
  </EventData>
  </Event>
The Information one:
Code: Select all
- <System>
  <Provider Name="Windows Error Reporting" />
  <EventID Qualifiers="0">1001</EventID>
  <Level>4</Level>
  <Task>0</Task>
  <TimeCreated SystemTime="2013-01-02T17:06:02.000000000Z" />
  <EventRecordID>15202</EventRecordID>
  <Security />
  </System>
- <EventData>
  <Data>-963443450</Data>
  <Data>1</Data>
  <Data>APPCRASH</Data>
  <Data>Not available</Data>
  <Data>0</Data>
  <Data />
  <Data />
  <Data>C:\Users\Spider\AppData\Local\Temp\WER145.tmp.WERInternalMetadata.xml</Data>
  <Data>C:\ProgramData\Microsoft\Windows\WER\ReportArchive\AppCrash_Action_x86.bin_8234e75283d78ed27b8f5646149b2a9cb41c170_3e7f054d</Data>
  <Data />
  <Data>0</Data>
  <Data>0</Data>
  <Data>dd2f95f31b08b31b46b5ed8f44484c82</Data>
  </EventData>
  </Event>
RazrBit
PC Specification: I7-3770K, HD6950, 8 x64, 8GB
Re: Action, Windows 8 and QuickSync
Thu Jan 03, 2013 10:55 am
I can confirm it, if I run Action! and have it set to I-mode in VirtuMVP, Action! instantly closes right after the GUI shows. The only way is to connect another display or whateverworkaround and delete the entry from VirtuMVP.
Thu Jan 03, 2013 11:02 am
Thanks for the report. I will forward this to the lab to see what's going on.
