Montago
Best Quality with QuickSync
Mon Mar 18, 2013 9:41 pm
SOLVED - Please skip to page 2, to see how the optimal setup of Action and Game should be !!
I'm a little sad that the quality of QuickSync is so poor at times...
I get lots of blocks and some gradient errors :-(
according to this guide it SHOULD be possible to get better quality with QS:
http://www.extremetech.com/computing/12 ... nscoding/5
They talk about CABAC, that it should be enabled (dont know much about encoders and decoders) - and dont know if its possible to enable while capturing.
I hope that your are working on improvements were possible...
IF there are settings available for the QuickSync encoder, my wish would be that you would enable me to fiddle with them, using an ADVANCED tab in the program. Thereby i could experiment with the settings to get the optimal video quality.
some examples below:
NOTE: all these images are from the same video !
BAD Quality 1
full size image
BAD Quality 2
full size image
GOOD Quality 1
full size image
GOOD Quality 2
full size image
GamerGuy
Re: Better quality with QuickSync
Tue Mar 19, 2013 3:27 am
In general I wish Action had much more video quality settings, both higher quality and also lower quality options to save filesize in certain usage scenarios.
Montago
Tue Mar 19, 2013 7:41 am
btw... I would prefer 2x larger filesizes when using QuickSync, if it was perfect quality...
QuickSync MP4 is already 2x larger than x264 encoded videos... so 4x wouln't hurt that much.
FRAPS and AVI settings is too big though :)
Tue Mar 19, 2013 5:32 pm
Next Action! update will include fixes for better video quality while recording with IQS.
Montago
Tue Mar 19, 2013 6:09 pm
radi wrote:Next Action! update will include fixes for better video quality while recording with IQS.
AWESOME ! :P
any chance i could be Beta Tester ? :mrgreen: ?
Wed Mar 20, 2013 3:43 pm
Montago, quick question. Your feedback is about exporting or real-time recording?
Montago
Wed Mar 20, 2013 3:46 pm
realtime recording...
GamerGuy
Wed Mar 20, 2013 7:42 pm
My feedback is also for realtime recording, specifically active desktop recording, where I would really like some even lower bitrate options. Video quality does not always have to be close to perfect, sometimes I just want to record long desktop sessions without using too much drive space.
Blutaar666
PC Specification: Phenom X4 955, Nvidia 570GTX, Win 7
Thu Mar 21, 2013 12:50 am
I would love to see better quality with quick sync when recording games. I also got a slightly worse performance than recording normally...
Thu Mar 21, 2013 12:35 pm
Montago wrote:realtime recording...
Good, you should see a significant improvement with next Action! update.
