Steam HUD issue
Mon Jul 29, 2013 4:47 pm
Hi guys,
recently some users reported that sometimes Action! is blocking their Steam Overlay. By analyzing lots of reports our support team came up with a solution. Please check if it works for you.
In one of previous Action! versions we've added a simple feature that allows you to exclude specific applications so Action! will simply ignore them.
One of Steam processes when you are running your Steam game is "GameOverlayUI.exe". Add this process to your exclude list. If you don't know how to add files to exclude list go to our tutorial here: http://mirillis.com/en/products/tutoria ... t.html#top
Let us know if that works. Your feedback is appreciated.
Edit:
One of our users confirmed that "gameoverlayui.exe" works for Win 8 x64.
ThAnoX
PC Specification: dsd
Re: Steam HUD issue
Mon Jul 29, 2013 5:43 pm
Work fine!
dimanish
PC Specification: i5-2500k, gtx680, 16GB ram, win 7 sp 1
Re: Steam HUD issue
Fri Aug 02, 2013 3:51 pm
Doesn't work for me. Still have no steam overlay with following scenario:
1. Start Action!.
2. Start Steam.
3. Start Half-Life 2.
Observe no steam overlay until exit from Action! and re-start Half-Life 2.
OS: Windows 8 x64
Kuntryboy
PC Specification: i5 3770K, EVGA GTX 670 FTW, Windows 8
Re: Steam HUD issue
Sat Aug 03, 2013 2:06 pm
I'm having either this same issue or a different one when launching Steam games. I have tried the suggestion about adding a text file and adding GameOverlayUI.exe to the list but I still get a crash when launching games.
My scenario is.... I have Action! running, I open Steam and launch a game. Then my computer hangs with a black screen. I have to force quit the game, quit action, restart the game, exit to the desktop, reopen Action! then it works. Strangely sometimes when I have this problem I have to Alt/Tab to the desktop, run task manager force quit the game then the game immediately runs and Action! runs correctly even though I just force quit the game. I don't have this problem when running games using Origin (BF3, Crysis etc.)
Any help with this admin and it would be a big help to an aggravating issue.
LodanZark
PC Specification: Corei7 3630QM, NvGT650M, Win8 x64
Re: Steam HUD issue
Wed Aug 07, 2013 6:09 pm
I add the process "gameoverlayui.exe"to your exclude list and didnt fixed the issue.
My specs:
Windows 8 Enterprise 64-bit´
Intel Core i7 3630QM
Intel HD Graphics 4000
NVIDIA GeForce GT 650M
8,00GB Dual-Channel DDR3 @ 798MHz
If someone need some feedback about a specific steam game i have here my library list which i can download and test the mirillis action performance:
http://steamcommunity.com/id/lodanz/games?tab=all
The steam games i tested to record so far were:
Killing Floor
Mortal Kombat Komplete Edition
Hotline Miami
Dark Souls
The game crashed exactly in moment i press f9 to record those games, then action did crashed itself.
LodanZark
Re: Steam HUD issue
Thu Aug 08, 2013 4:27 am
All my games from steam crashs after start recording with mirillis action, i already added GameOverlayUI.exe to exclude list but didnt fixed the issues.
My specs:
Operating System
CPU
Intel Core i7 3630QM @ 2.40GHz
RAM
Graphics
Screen 1920x1080@60Hz
Hard Drives
699GB Hitachi HTS547575A9E384 (SATA)
dimanish
Re: Steam HUD issue
Sun Aug 11, 2013 6:48 am
Or for example steam overlay doesn't work in Dishonored if Action! started. If I quit Action! and re-start game steam overlay appears. I have added both gameoverlayui.exe and GameOverlayUI.exe to exclude.txt - still not help...
If Action! started GameOverlayUI.exe doesn't even executed after I start Dishonored (I monitor Task Manager)...
radi, do you need some additional information? Logs, Action! settings etc?
This bug is very annoying.... :(
Re: Steam HUD issue
Mon Aug 12, 2013 4:45 pm
Well, if Steam HUD works properly when you run Action! as second app after Steam it may mean that Action! and Steam gets confused while trying to plug into the same process at the same time.
sentinelvdx
PC Specification: i7 2600K, 16GB 2133Mhz, HD7970
Re: Steam HUD issue
Mon Aug 12, 2013 5:06 pm
dimanish wrote:Or for example steam overlay doesn't work in Dishonored if Action! started. If I quit Action! and re-start game steam overlay appears. I have added both gameoverlayui.exe and GameOverlayUI.exe to exclude.txt - still not help...
Same problem here
MrTra1tor
Re: Steam HUD issue
Sat Aug 02, 2014 11:22 am
Can I block Skype using this feature? Like if I only want the game's audio (some of my friends will never shut up) I can simply add Skype to the ignore list and it will be ignored? Or is it entirely UI based?
