alv973
PC Specification: intel 4770k, GTX 780, Windows 8pro 64 bt
SRFeature.exe error message
Mon Oct 07, 2013 4:22 pm
I just bought Action! and now when I start the soft I have an error message : SRFeateure.exe
instruction 0x59a35f85 at adresse memory 0x00000104 can not be read.
my computer :
Windows 8 pro 64 bits
intel 4770k
Asus Z87 pro
Nvidia GTX 780
32 GB ram
SSD crucial 960 GB
Re: SRFeature.exe error message
Mon Oct 07, 2013 5:54 pm
Could you post full error log?
alv973
Mon Oct 07, 2013 6:53 pm
SRFeature.exe error
radi wrote:Could you post full error log?
yes
I had join a screen capture.
It's wrote in french :
SRFeature.exe - Erreur d'application
L'instruction à 0x501d5f85 emploie l'adresse mémoire 0x00000104. la mémoire ne peut pas etre en état "read".
Tue Oct 08, 2013 12:03 pm
It seems that the SRFeature.exe error is related to Splashtop Streamer software. Try adding SRFeature.exe to Action! exclude list. You can find a tutorial here: http://mirillis.com/en/products/tutoria ... t.html#top
alv973
Tue Oct 08, 2013 3:55 pm
Yes you are right
The problem desappear when I stop splashtop streammer.
Thank you for your answer.
