hlbnet
PC Specification: Intel Core i7 2670QM, Nvidial GTX580M
Xvid4PSP 6 and Freemake VC can't read captured AVI
Sun Oct 20, 2013 11:06 am
Is there a free video converter that can be used to convert AVI files captured with Action! ?
I tested Freemake Video Converter and Xvid4PSP 6. Both can't read the AVI files created by Action!
I know there is a convert function in Action! (called Export), but the quality of the video it produces is low (for a given bitrate).
Thanks.
Re: Xvid4PSP 6 and Freemake VC can't read captured AVI
Mon Oct 21, 2013 4:56 pm
which settings did you use with Action! export?
hlbnet
Mon Oct 21, 2013 6:10 pm
Thank you for your answer.
In the Exportation panel I have (sorry, it's in French) :
Profil : Auto
Qualité de la vidéo : Haute, 1920x1080
Bitrate vidéo : 6.024 Mbps
Piste sonore : Son 01
Son : Stéréo
Dimension de départ : ~27MB (8%)
In the parameters for export, I have :
Checked = User l'accélération matérielle pour encoder la vidéo
NVIDIA CUDA
I have made additionnal tests and I realized that, when NVIDIA CUDA is used, the quality of the exported video is not as good as expected for a 6 Mbps MPEG-4 video. When I uncheck hardware acceleration for export, the exported video is as expected (I made a visual comparison with the same scene captured with another capturing tools and converted to 6 Mbps MPEG-4).
So, I will now let this option unchecked and I consider my problem is solved.
Regards.
Tue Oct 22, 2013 2:54 pm
Well 6Mpbs is not a top notch quality, but it should be good for a 27mb file. CUDA may lower your quality, but it's much quicker to export video than without it.
