nostradamus
PC Specification: 8800 GTS 512 Windows 7
Splash Pro or Even Splash Lite Video Too Dark In Windows 7
Tue Nov 29, 2011 10:22 am
Hi i recently installed windows 7 ultimate 64 and the any video i open in splash is incredibly dark, i can adjust the saturation,brightness and contrast but it's still not the same as it was in win xp, in xp i didn't have to adjust anything it was just perfect. is there a way to resolve this problem or the best way is just to install win xp?
P.J
Re: Splash Pro or Even Splash Lite Video Too Dark In Windows
Fri Dec 09, 2011 11:44 pm
Did you install the latest Forceware driver?
You can also change many settings in Nvidia control panel.
nostradamus
Sat Dec 10, 2011 4:36 pm
P.J wrote:Did you install the latest Forceware driver?
I did install many different versions of the forceware drivers but still the same problem. My main problem is the fact that in windows xp i didn't have to change anything in the driver settings or the player and it was perfect the default settings are perfect but in windows 7 there not. I did play around with the settings in the nvidia control panel and in the player settings but i still don't get the same picture quality like in xp. Also with other players( bsplayer,vlc,kmplayer) the picture quality on win 7 is exactly like in xp but those players are crap, splash is way better then the rest.
P.J
Sat Dec 10, 2011 8:22 pm
Strange. Did you try these: :?
Would you take screenshot in both Win7/XP?
nostradamus
Sat Dec 10, 2011 10:04 pm
P.J wrote:Strange. Did you try these: :?
I just tried this Thanks Man it worked perfectly, when Force Video Overlay is enabled it's the same quality like xp.
It was disabled and I didn't touch it because i didn't know what it does.
Again Thanks Man it works perfectly. :mrgreen:
P.J
Fri Dec 16, 2011 7:00 pm
Your welcome :D
Anyway, it's not good way because forces to use Basic theme and else.
Do you get the dark problem with Windows Media Player 12 too? :?
nostradamus
Mon Dec 19, 2011 8:08 pm
P.J wrote:Your welcome :D
No only Splash has this problem.
P.J
Mon Dec 19, 2011 8:53 pm
Strange, would you provide the video file? :?
nostradamus
Tue Dec 20, 2011 1:50 am
P.J wrote:Strange, would you provide the video file? :?
Sorry but i don't understand what exactly you want. If you're talking about the video file which in splash is very dark, it's not just a video, it's every video it doesn't matter what it is. Every single video/movie I opened in splash was very dark, until you told me about that option.
P.J
Sat Dec 24, 2011 8:33 pm
Oh, may you provide a screenshot from Splash and Windows 7's media player 12? :?
