MatG-DK
PC Specification: i7 4700HQ, GTX780M, Windows 8 x64bit
Outlook 2013 not starting up if Action! is running
Fri Apr 04, 2014 7:39 am
Hi there, just found another bug that bugs me..
If i have Action! running (in taskbar etc.) its impossible to start Outlook 2013.
The program tryes to start, but hangs in starting up. I can see that the Outlook 2013 window has the Action! bars in it, so im guessing it has something to do with that?
When i shut down Action! the Outlook 2013 starts without any problems!
Could u plz look into that?
Regards
Re: Outlook 2013 not starting up if Action! is running
Fri Apr 04, 2014 7:53 am
Which Action! version do you use?
MatG-DK
Fri Apr 04, 2014 7:56 am
Just the latest trial version 1.19.1.0
Fri Apr 04, 2014 8:00 am
MatG-DK wrote:Just the latest trial version 1.19.1.0
Find the Outlook 2013 process in task manager and try adding it to exclude list.
http://mirillis.com/en/products/tutoria ... -list.html
MatG-DK
Fri Apr 04, 2014 8:07 am
That helped :D :D :D
Thx alot 8-)
