Spookas
PC Specification: i3-2120, GT 630, Windows 8.1
1280x676 forced resolution
Thu May 15, 2014 1:21 pm
Hello, guys.
I have a problem with my video quality, everytime I record anything from Minecraft to Just Cause 2 on ANY resolution, Action! sets it to 1280x676, which is a low quality resolution. I don't want my video quality to be bad, because I wan't to upload my recorded footage to youtube. Here are some pics:
Spookas
Re: 1280x676 forced resolution
Tue May 20, 2014 1:47 pm
I'm still waiting, because of this error I've reinstalled my OS 3 flippin' times.
DIGG
Tue May 20, 2014 5:41 pm
Well you did choose 720p, which would give 1280x720 resolution... how can you be sure it's 1280x676, where are you seeing that number? I'd like to see.
Wed May 21, 2014 3:59 pm
What's your game resolution and screen resolution?
Spookas
Thu May 22, 2014 5:19 pm
radi wrote:What's your game resolution and screen resolution?
When I recorded both were 1920x1080, but my monitor recommends a bit lower resolution.
DIGG wrote:Well you did choose 720p, which would give 1280x720 resolution... how can you be sure it's 1280x676, where are you seeing that number? I'd like to see.
Take a closer look.
DarkMain
Fri May 23, 2014 4:26 am
Bottom left hand corner of the first image.
Kinda odd as the vertical resolution is correct (1280) but the horizontal is off.
Is the recorded video cropped? Squished? or does it look normal when its played back?
Spookas
Sat May 24, 2014 12:36 pm
DarkMain wrote: Kinda odd as the vertical resolution is correct (1280) but the horizontal is off.
Hello, the recorded footage is really bad quality - the colours are off and as I mentioned before, the resolution is smaller.
Tue May 27, 2014 6:46 pm
Users browsing this forum: No registered users and 52 guests
