SkyrimTuner
PC Specification: i5-2500K, GTX 780 3GB, Win7 64, 16GB DDR
blue and cyan artefacts after exporting
Fri May 30, 2014 5:52 pm
Hello!
Because Pinnacle does not accept Action! AVI-files i have to export it to mp4 before editing.
but the exportet files have blueish and red artefacts. if i increase the quality of exporting
it gets better but issue is not gone, nevertheless which settings are used. happens in every video after export.
see it for example here in minute 7:02 in background on edges of cash machine
https://www.youtube.com/watch?v=gZGLT_U ... mjlxDTapwg
happens mostly on movements.
original Action! AVI files are fine without any problems, only exported MP4 are affected.
Would be very nice to have a solution, Thanks.
Re: blue and cyan artefacts after exporting
Wed Jun 04, 2014 5:13 pm
Do you export your video files using Action! built-in exporter or an external application?
SkyrimTuner
Wed Jun 04, 2014 5:33 pm
i'm exporting with Action! itself 1080p high profile, quality high 1920x1080, maxed bitrate
if i do not export the recording, there are no artefacts, they are caused by export using Action!
lower bitrate --> many artefacts, max. bitrate fewer artefacts but not gone
effect ist stronger in dark scenes, look here at minute 14:40, 14:48, 15:20, 15:22, 15:31, ...
https://www.youtube.com/watch?v=syx-Z7_ ... mjlxDTapwg
deactivating Nvidia hardware acceleration helps a bit i guess
