Gamersitic34
PC Specification: i5-440, gtx 780, windows 8.1
Action setting not in effect
Thu Jul 24, 2014 11:28 pm
Hi, I have had a very annoying issue with Action since I bought it where even through I tell it to record at 720p 60 fps in mp4 format but when I hit the record button the fps goes down and locks at 30 until I tell it to stop, and when I look at the file in the action window it says it was recorded at 854x480 at 30 fps whitch is a huge pain and I have reinstalled but nothing changes. HELP!
Re: Action setting not in effect
Fri Jul 25, 2014 6:50 am
Do you use hardware acceleration to record your video in MP4 format? (Intel Quick Sync or AMD APP).
Gamersitic34
Fri Jul 25, 2014 7:14 pm
No, I don't have anything of that sort running while I record or even installed
Mon Jul 28, 2014 4:43 pm
Software MP4 encoding is limited to 720p and 30 fps, that's probably the reason of your issue.
