cadkins90
PC Specification: i7 4770k, 8GB DDR3, GTX 560Ti, Windows 8
Recording gets cut off...
Mon Jul 28, 2014 2:25 am
I recorded bunch of my league of legends gameplay and When I check the recording after the game, it only saved the first minutes of gameplay.
The overlay was red the whole time and supposedly recorded the whole thing, I stop the recording after the victory screen is showed.
I'm using Intel Quick Sync and MP4 audio.
It works fine with normal MP4 (maxes out at 30fps) but I want to use Quick Sync (60fps).
Can you please help me?
I don't know if it will help but when I put these "corrupted" videos in Vegas, it shows that the audio is cut shorter.
Can you please help me? Thanks!
Re: Recording gets cut off...
Mon Jul 28, 2014 4:36 pm
If there is an issue with IQS please check if you have latest drivers installed on your PC.
Users browsing this forum: No registered users and 52 guests
