razama
PC Specification: R9 270x 2GB graphics card, Windows 7, i5
Trouble with hotkeys
Thu Aug 07, 2014 6:47 am
I am having an problem using hotkeys that only recently started. While I can set and change the hotkeys from their default keys, I cannot actually use them. This has kept me from using the mode to record games and applications, but I can still click on the record button when in "active screen" mode. I can then open or tab to whatever other program I want to record and everything works perfectly fine, besides the hotkeys of course.
I have noticed that the check boxes next to the hot keys are unchecked, and I can't click on them to re-check them. The only real fix I have tried so far is uninstalling the program, running CCleaner's Registry Cleaner, and then reinstalling the program. All my changes to the hotkeys still existed when I reinstalled, the checkboxes are still unchecked, and no combination of hotkey setups has changed my ability to check them.
I am currently running a trial version and really liked the program up to this point, but I am a bit apprehensive about buying a full license until I can get this issue resolved.
Re: Trouble with hotkeys
Thu Aug 07, 2014 3:10 pm
Could you post a screenshot from your Hotkeys tab?
Jesper JJ
PC Specification: i7-4770K|GTX780|16GB ram|maximus gene vi
Fri Aug 08, 2014 12:25 am
1. search for "regedit" in run
2. navigate in registry to: HKEY_CURRENT_USER\Software\Mirillis\Action
3. delete the Mirillis folder
this fixet my hotkeys :D
Desktop 08-08-2014 02-04-59-696.png (82.46 KiB) Viewed 7111 times
razama
Fri Aug 08, 2014 2:30 am
Only moments ago I was able to solve the problem myself! :D
At the suggestion of a friend, I went into the registry editor myself and checked if Action! had been removed or not. It wasn't, and running CCleaner, Advast!, Malware Bytes, and a few other Registry Cleaners (for curositiy's sake) did not remove it. I manually deleted the registry, re-installed Action!, and everything works perfect again.
I'm not sure what caused the issue in the first place though :|
