Excession
PC Specification: Windows 8 i5 core no discrete graphics
Pause won't work.
Thu Aug 21, 2014 11:42 pm
Hi. Using Win 8 and currently a day into trial version.
Action seems to work fine except it won't pause.
The shift+F9 didn't work so I deleted registry and reinstalled. I also installed android remote control app.
Both worked (i.e paused recording) for literally one test vid - and now they won't work again.
The normal F9 and 'stop' button on android remote work, but pause is broken.
I'm doing gameplay vids for a strategy game so I really do need to pause the game whilst I micromanage boring stuff...
Is this a known issue? I'm happy to buy Action! if it does want I need - but no pause would be a game-breaker for me...
Also I cant change the hotkeys - no matter what I do with registry deletes and reinstalls.
Re: Pause won't work.
Fri Aug 22, 2014 9:35 am
Please make sure that you have AVI format set. Pause feature is not available for MP4 videos.
Excession
Fri Aug 22, 2014 5:20 pm
Ah, OK.
Thing is, youtube seems to take ages and often crash when uploading and converting long avis, whereas 720p mp4s work brilliantly.
I don't have an avi to mp4 converter either. Is there one built in or a decent freeware one available?
Wed Aug 27, 2014 5:45 pm
You can use Action! built-in exporting feature.
ElectroPositive
PC Specification: i5-3570K, AMD R9 280X, Windows 8.1 P x64
Fri Nov 07, 2014 9:46 am
I have a "Steam" version. I use hardware encoding "Intel Quick Sync" when recording video. Will make a function to pause the video format "MP4"?
Mon Nov 10, 2014 4:36 pm
Yes, new version will allow you to pause MP4 videos.
