jamin000
PC Specification: i7-2600, 970 GTX, 16 GB ram, Windows 7
Action has Stopped Working
Thu Nov 27, 2014 2:15 pm
Getting the 'Action has stopped working' message every time I try to load the software - it was running fine for a few months and this just started today! Any advice would be greatly appreciated.
Thank you
Re: Action has Stopped Working
Thu Nov 27, 2014 2:25 pm
Try removing or moving to another location all your files from your output folder. Let us know if that helps.
jamin000
Thu Nov 27, 2014 2:34 pm
Thanks for the reply! I've already tried to uninstall/reinstall the software with no luck, is this what you were saying to do or something else?
Thank you!
