zxthad
PC Specification: Windows 7
Settings not saving
Fri Jan 02, 2015 12:28 am
So I recently got Action! on steam, (only to find out that its 11 dollars cheaper on this website) and whenever I edit the settings, it doesn't save when I re-open it. Also, if I minimize the program, I have to close it using task manager and then re-open it to see the window with all the settings and saved videos.
I'm not sure if its just because the steam version is buggy, but I would love some help.
Thanks in advance.
Re: Settings not saving
Tue Jan 06, 2015 2:26 pm
Try running Steam app as administrator and see if you are getting the issue.
Users browsing this forum: No registered users and 48 guests
