freeleecher
PC Specification: 2700k 2x290 windows 7
It dont work at all
Wed May 13, 2015 9:42 am
The demo worked fine but after buying it no longer works.
2700k@ 4.8 2x290 cards 2560x1440 res 60 htz
I press f9 the numbers change to red making me think its working when in fact it is not.
Zero upload speed on task manager.
Pcars, gtav, alien isolation.
Using the latest graphics drivers.
Why does this program say its working when you cant exactly alt tab or alt enter to check without it wrecking the stream.
It says its recording when it shoudnt making me waste hours when in fact its not working at all.
Re: It dont work at all
Wed May 13, 2015 2:19 pm
There is no technical difference between trial and activated version except for the watermark. If you experience any technical issues please report them to our support team via support@mirillis.com.
freeleecher
Wed May 13, 2015 7:14 pm
I cant pinpoint a exact fault other than its not working.
Pointless to report,
It must be something my side because it did work.
http://www.twitch.tv/freeleecher/v/4989405
It did work here but I have no idea why it does or don't.
