disi
PC Specification: AMD all the way
Darksiders trigger screenshots problem
Mon May 18, 2015 12:02 pm
In Darksiders, if you use a controller, it disables any keyboard input while playing. I cannot even Alt+Tab or anything from the game.
I tested to record a video with Action!. Starting it before I start the game and it recorded the whole session just fine.
Is there another way to trigger a screenshot? Or do you guys know any workarounds?
My default screenshot key is multiply(*) on the NumPad.
You can use PrtScn in the game, end the game, open paint and then paste the clipbrd content. I tried setting PrtScn as my screenshot button for Action, it works as long as the game isn't started and then it stops.
OS: Windows 7
Video Card: AMD
Memory: 32 GB
Monitor Resolution: 1920x1080
Video Editor: ?!?
Game Problem: Darksiders
Video Type: png
p.s. this is the GOG version (no SteamClient-Overlay thingy).
Mouse input seems to be active while playing, but I cannot assign hotkeys for it in Action! to make screenshots in the settings menu. If I assign a keystroke like Num* to my mouse button, it doesn't work either since it is a keyboard input.
Added support for extended mouse keys as hotkeys
It states this for version 1.12.x https://mirillis.com/en/products/action_history.html
disi
Re: Darksiders trigger screenshots problem
Tue May 19, 2015 7:07 am
And yeah, in The Witcher3 it automatically detects input devices.
In order to make a screenshot, I have to release the controller, hit any key on the keyboard (the input scheme changes), hit the screenshot key, do something on the controller (the input scheme changes), fight on -.-
Tue May 19, 2015 2:05 pm
Please report this issue to our support team via support@mirillis.com.
disi
Wed May 20, 2015 6:44 pm
I found a workaround using a foot pedal :)
Now I can play using the controller and take screenshots or start recording with the pedal.
Wed May 27, 2015 3:56 pm
You are my hero! It's far the most impressive workaround that has been posted here around the forums!
