Skyhel
PC Specification: i5 2.8Ghtz
Recording problem
Sun May 31, 2015 11:10 pm
Hello !
Please i buyed Mirillis caus it's the bast way to reacord with quality after trying it.
But when i record i got this problem :
here another screen with all vidéo i made...
Please help me ! :(
Re: Recording problem
Mon Jun 01, 2015 10:03 am
What's your game resolution?
Skyhel
Mon Jun 01, 2015 10:34 am
My game resolution can be
400x840
800x960
1600x960
1600x1920
i got the same problem with any of this resolution :/
Skyhel
Mon Jun 01, 2015 2:47 pm
So no solution ?
Tue Jun 02, 2015 9:45 am
That depends on what is your current game resolution. If the aspect ratio is 4:3 you will always have black bars on the side.
Skyhel
Tue Jun 02, 2015 10:17 am
But with another program working good... But I won't buy for all program...
They have no option for resise the program like another program do ? Then we well work good...
Tue Jun 02, 2015 11:24 am
Skyhel wrote:But with another program working good... But I won't buy for all program...
What's your game name? I will try to reproduce this issue on my side.
Skyhel
Tue Jun 02, 2015 2:12 pm
Monster Hunter 4 Ultimate, using 3DS capture card from http://www.3dsvideocapture.com/
with another program i got the same problem, but this program have some setting to fix this problem...
But mirillis have no setting to fix ths problem, and i prefere mirillis caus the cuality is better ...
Skyhel
Wed Jun 03, 2015 12:02 am
Solved.
Mon Jun 08, 2015 5:48 pm
Skyhel wrote:Solved.
Could you share your solution with us?
