kazeookami
PC Specification: Windows 7
Crash on launch
Sat Jun 13, 2015 3:55 am
So I am trying to launch Action and it's pretty much telling me where to go shove it. I see the splash screen and then a 'program has stopped working' generic error message from windows. I've tried turning off anti-virus, I've tried rebooting, I've tried fetching windows updates or drivers updates. Nothing changes that I can see.
OS: Windows 7
Video Card: AMD Rageon HD 6520G
Memory: 4gb
Monitor Resolution: 1600x900
Re: Crash on launch
Sun Jun 14, 2015 7:52 pm
Check for latest drivers for your AMD card. It's a common issue with outdated video drivers.
kazeookami
Re: Crash on launch
Mon Jun 15, 2015 9:24 pm
radi wrote:Check for latest drivers for your AMD card. It's a common issue with outdated video drivers.
Thank you for the canned reply that deliberately ignores that my original post said that I did those drivers.
Hondo
PC Specification: i7 4790K, 2xEVGA GTX 980, Win 8.1, 16gb
Re: Crash on launch
Wed Jun 17, 2015 3:06 am
I am also getting the same. I wanted to try out the trial version before buying but I have not been able to run it once.
I get the splash screen and then it crashes. Here is the logs from event viewer.
Faulting application name: Action_x64.bin, version: 1.25.3.0, time stamp: 0x556dca9f
Faulting module name: Action_x64.bin, version: 1.25.3.0, time stamp: 0x556dca9f
Exception code: 0xc0000005
Fault offset: 0x00000000000044e7
Faulting process id: 0x1238
Faulting application start time: 0x01d0a8a98dde3e2a
Faulting application path: C:\Program Files (x86)\Mirillis\Action!\Action_x64.bin
Faulting module path: C:\Program Files (x86)\Mirillis\Action!\Action_x64.bin
Report Id: cbabfd9d-149c-11e5-83ae-10c37b6cbe53
Faulting package full name:
Faulting package-relative application ID:
Faulting application name: Action_x86.bin, version: 1.25.3.0, time stamp: 0x556dcb10
Faulting module name: Action_x86.bin, version: 1.25.3.0, time stamp: 0x556dcb10
Fault offset: 0x0000436f
Faulting process id: 0x19d4
Faulting application start time: 0x01d0a8a98dccfb83
Faulting application path: C:\Program Files (x86)\Mirillis\Action!\Action_x86.bin
Faulting module path: C:\Program Files (x86)\Mirillis\Action!\Action_x86.bin
Report Id: cb9d2cdb-149c-11e5-83ae-10c37b6cbe53
All my drivers are up to date.
My PC specs:
i7 4790K
16gb RAM
2 x EVGA GTCC 980 - SLI
WIndows 8.1
Any help is greatly appreciated.
Thanks,
Hondo
Re: Crash on launch
Thu Jun 18, 2015 10:22 am
