choco75
PC Specification: windows 8
Multi monitors
Mon Aug 29, 2016 11:40 am
I have 2 monitors. I would like to work on 1st one and to record videos in same time on 2nd monitor.
I put video to record on 2nd monitor, select 'active desktop region' on Action! select the area to record on this 2nd monitor and start the record.
Pb is that it is recording my 1st monitor, not the area I have selected on 2nd one :?
Thanks for your help :idea: ;)
4furlongs
PC Specification: Win 10
Re: Multi monitors
Thu Oct 13, 2016 11:56 am
I had the same problem for the same goals. I found the solution in an old post by ndollimo in 2014:
"Postby ndollimo » Fri Oct 10, 2014
...you need to have the HUD enabled to be able to switch the active desktop. You'll see it change by the HUD being lit blue for the active desktop. Using the shortcut to switch, you'll see the HUD lighting change as the active monitor changes. After doing this and testing recording, it works."
Note that it's not necessary to select the "active desktop region", just the entire screen.
If Action! is recording the "wrong" window, press F8 to change the "active window" it records. Works well for me. It seems to stay on that screen, too, until you press F8 again. I can't see any way to check which screen is actually being recorded during the recording however.
In theory, you can also change the hot key to alternate the active window, but I haven't been able to do so yet.
Enjoy!
