anonimero
PC Specification: Windows 10 Pro, Intel Core i7-5820K etc
Own watermark with unwanted shadow
Tue Nov 08, 2016 12:45 pm
I am using a png24 file as a small watermark in the upper right corner. To fix it to a defined position I use a logo centered on a small transparent background. But instead of being fully transparent, the background appears as a shadow-like area (see attachment: action-wasserzeichen-fehler.png [on the right]) in every game I record (e.g. GTA V, The Elder Scrolls Online etc).
I use the same file (see attachment: logo_a_neu_rand_kl.png) with OBS, PlayClaw and D3DGear without having this weird problem. And using the file with Photoshop does not show up the "shadow" (see attachment: action-wasserzeichen-fehler.png [on the left]).
Maybe it is no problem with Mirillis Action! but with some settings so I ask you for help.
(Sorry for mistakes, English is not my native language)
Kind regards
The used watermark file
On the right: watermark as it appears in the video; on the left: same watermark file put in with photoshop
Re: Own watermark with unwanted shadow
Wed Nov 16, 2016 4:12 pm
Fixed in 2.0.1.
