misterbung
PC Specification: i5-25000K @ 3.2ghz, 32gb RAM, AMD R9 390
Simple 'recording' symbol?
Sun Nov 13, 2016 8:22 am
This may be somewhere tucked in a Settings option, but is there a simple way to have an icon showing if you're recording or not?
Shadowplay does it well with the small symbol tucked in the bottom right corner and given Action! is a paid platform, I would hope it either already has it or is going to be implemented soon.
Re: Simple 'recording' symbol?
Wed Nov 16, 2016 4:09 pm
Action HUD shows your current record status. Blue HUD is for idle, red HUD is for recording.
