roptopgames
PC Specification: Windows 11 Pro, CPU I5 13500H
Black Screen on Recordings after Windows Update 24H2
Wed Nov 12, 2025 9:27 am
I recently updated to Windows 11 Version 24H2, and now I am encountering a critical issue with Action!
Whenever I try to record Desktop or Gameplay (using the active screen mode), the resulting video file has audio but a completely black screen.
Steps I have taken (Troubleshooting):
I have tried both MP4 and AVI recording formats—the issue persists.
I completely uninstalled and reinstalled Action!
I have reverted my NVIDIA driver to an older version (555.85), but that did not fix it.
If I switch to Active Desktop Region recording, it works correctly, but I need the full-screen mode for games.
This leads me to believe there is a compatibility issue between the latest Windows update and Action!'s screen capture method, specifically the display driver interface.
Has anyone else experienced this, or does anyone have a fix?
Product: Mirillis Action! Version: 4.29.3 (Latest stable build) OS: Windows 11 Pro (Version 24H2) Graphics Card: NVIDIA GeForce RTX 3070 (Driver 555.99)
Thank you!
dockinfinite
PC Specification: Core i7, NVIDIA, Windows 11
Re: Black Screen on Recordings after Windows Update 24H2
Fri Dec 26, 2025 2:25 am
You’re not alone — this is a known compatibility issue between Windows 11 24H2 and Action!’s full-screen capture method, especially on NVIDIA GPUs.
What’s happening
Windows 11 24H2 introduced changes to the Desktop Window Manager (DWM) and graphics capture pipeline. Action!’s Active Screen / Gameplay (full screen) mode relies on low-level hooks that currently fail to receive video frames, resulting in:
✅ Audio recorded correctly
❌ Video output = black screen
The fact that Active Desktop Region works strongly confirms this is a screen capture API / driver interaction problem, not a codec or installation issue.
sabirose
PC Specification: CPU
Mon Jan 05, 2026 3:55 am
looks like a Windows 11 24H2 compatibility issue with Action!’s fullscreen capture—nothing on your end.
Denyroman
PC Specification: Windows 10
Wed Jan 28, 2026 2:18 am
Having similar issues capturing full-screen games? I did! Switching to older drivers (like you tried) didn't work for me either. What *did* help was running the game in a windowed-fullscreen mode instead of exclusive fullscreen.
