cee320
PC Specification: Win10 x64 RTX 3060
Constant crashes under 4K (200% scaled)
Mon May 04, 2026 10:30 am
Action: 4.48.0.0
OS: Windows 10 x64 22H2
GPU: Nvidia RTX 3060 12GB
Hello, I have been using Mirillis Action for many years and have been very happy with the performance and quality. I ran a dual-monitor 1920x1080 setup but I recently replaced the primary with a 4K 3840x2160 OLED display, scaled to 200% to mimic 1080p via Windows 10's builtin Scale and layout setting display. I'm getting constant crashes and broken windows trying to run Action now. I can occasionally take a screenshot or two, but trying to record video results in a crash. Many dropdown menus and other Action UI elements, such as selecting encoding format, display as invisible when clicked (for example, clicking File format causes the "MP4" text color to change, but the actual dropdown list does not appear). Opening the excluded process list starts to draw the list of already excluded processes, then hangs for a few moments and ultimately results in a crash. Even doing nothing, the program eventually crashes after a minute or so. Occasionally, a crash results in my monitor blanking briefly and possibly crashing another random program (which is why I wanted to try excluding more processes, but have been unable to do so). Does anyone have any advice how to make it work with this setup?
pinionbrewer
PC Specification: PU model
Re: Constant crashes under 4K (200% scaled)
Wed May 06, 2026 9:42 am
This is not unusual, particularly when scaling from 1080p to 4K at 200% on Windows 10. 4K displays require extra processing power, especially when recording at high resolutions. If drivers are not up to date or are incompatible, screen recording software such as Action may freeze or crash.
Elise Sims
PC Specification: CPU model
Fri May 08, 2026 8:40 am
Wow, that sounds frustrating! It seems like the high resolution and scaling are really throwing Action for a loop. I haven't used a 4K setup with it myself, but I wonder if it's struggling with the increased processing load. Have you tried experimenting with lowering the recording resolution within Action itself, even if your display is scaled up? That might reduce the processing burden. Also, is your GPU driver fully updated? Perhaps there's an incompatibility with the way Action interprets the slope of the scaling, causing these visual glitches and crashes. Worth checking that out. Good luck!
sorenhy351s
PC Specification: 26
Fri May 15, 2026 4:35 am
Have you tried right clicking Action.exe, going to Compatibility and overriding high DPI scaling behavior to Application or System Enhanced to see if stability improves?
ftingentr
PC Specification: Windows 11 Pro 23H2 CPU: Intel Core i7-1
Thu May 21, 2026 7:15 am
Sounds like a DPI scaling issue with the new 4K setup. Try lowering Windows scaling from 200% to 100%/150% and test again. Also update GPU drivers and disable overlays like GeForce Experience or RTSS — the invisible menus and crashes seem more like a UI compatibility problem than hardware-related.
felixandrea
Sat Jun 13, 2026 8:38 am
Action: 4.48.0.0
What you're describing sounds like more than just a recording issue. The invisible dropdowns, broken UI elements, and monitor blanking make me think there may be a DPI scaling or graphics-driver compatibility problem rather than a pure Action recording bug.
A few things I'd try:
Set Windows scaling temporarily to 100% or 150% and see if the UI behaves normally.
Right-click Action.exe → Properties → Compatibility → "Change high DPI settings" and experiment with the DPI scaling override options.
Perform a clean install of the latest NVIDIA driver using DDU if you recently upgraded the monitor.
Disable any overlays (GeForce Experience, Discord, MSI Afterburner, RTSS, etc.) to rule out conflicts.
Try running Action on the secondary 1080p display only and see if the crashes stop.
The fact that opening the excluded process list can crash the application suggests the issue is affecting the UI framework itself. If lowering the DPI scaling immediately improves stability, that would be a strong clue that the 200% scaling on the 4K display is triggering the problem. I'd also check whether Mirillis support has a newer beta build, as high-DPI issues sometimes get fixed between public releases.
