Nowadays, there are so many different screenshot capture tools on the market, that all you can get while considering different options is just… a headache.
Nevertheless…
Did you know that a screen capture app can help you save a lot of your time and effort on making notes, rewriting texts or describing pictures and charts? All you need to do is simply… to take a screenshot of what you need within the fraction of a second and that’s it.
In this article, we will help you to find the most suitable screen capture software in terms of quality and performance and we will tell you how to quickly take a high-resolution screenshot.
But first…
What is a screenshot? Well, to make the definition most simple…
Screenshot is a digital image of what you see on your computer’s monitor or any other output device, that can be saved as a picture or graphic file to different formats (JPG, PNG, BMP, etc.). A screenshot is usually created by means of screenshot capture program running on the device or alternatively, by the operating system.
So, you may think: What kind of screenshot grabbing app do I exactly need?
First of all, you need fast screenshot maker that you will be able to use quickly, easily and very intuitively, right?
Secondly, you should be able to capture anything visible on your screen in high quality. By “anything” we mean screenshots of the applications you use, games you play, web pages you check, videos you watch and basically
E-V-E-R-Y-T-H-I-N-G you see on your computer’s screen.
What next?
The application you choose shall offer at least three modes of taking screenshots/ screen capture modes, which are:
1) Screenshot of a Full Screen
2) Screenshot of a selected part of your screen or a specific region of your screen
3) Smart Window Detection – What’s that?
Smart Window Detection is an option where your chosen application is so smart, that it automatically guess your intentions of what you want to make a screenshot of. One can say..almost reading in your mind, right?
Well, almost.
Action! Screen Recorder, for example, offers an option which is called “Snap to windows”. Thanks to this feature the program detects the window you are interested in and automatically adjusts itself to the window’s frame. After adjusting to the frame, all you need to do is to click the window to make the borders stable and take a screenshot. To take a screenshot you may click the icon on the interface or hit the hotkey which is F12 by default.
Download Action! 3.0 right now!
If you would like to see: How to take a screenshot in a fast and easy way, check the video below:
So far so good, but what other features may I need.
Well, everything depends on your needs and preferences but why not to consider having everything at once?
Let’s say you would need to capture a video with your application. And not just a typical, standard video but Ultra HD quality video including webcam, audio and voice commentary.
Would you like to have such a possibility?
If yes, Action! 3.0 is a perfect option for you. Apart from taking high-quality screenshots of a Full Screen and selected part of your desktop, it offers few really robust screen recording modes namely:
1) Game recording mode – dedicated for Gamers of course
2) Screen recording mode for e-learning, education purposes, classroom activities, webinars, tutorial guides, Skype or Hangout calls, etc. ? possibilities are countless!
3) Area recording mode – according to preferences
4) Device recording mode which allows you to capture video from your PS4, Xbox or other external devices like TV, mobiles, etc. – for everyone
You may think: Wow, that’s awesome, I’m not only allowed to grab a screenshot but also to grab a whole video file in HQ resolution. Yes… that’s right. In case of Action! you are allowed to capture your screen in up to 4K resolution and even up to 8K resolution in AVI.
Crazy, isn’t it?
But it’s still not everything.
With Action! 3.0 Drawing Panel you can annotate screenshots instantly: add lines, text, shapes, use freehand drawing tool, add arrows, highlights and much more actually. All you need to remember about, is that all annotations must be done before the screenshot is made.
Action! is a feature-packed and simple screen capture software. Intuitive interface enables you to access and manage your files easily and quickly. Build-in video manager allows you to stay logged into your social media accounts like YouTube, Facebook, Twitch, Smashcast or any custom RTMP destination.
As you can see Action! is a super easy-to-use and professional desktop tool with… countless possibilities!
So…
If you are looking for a good, super fast and easy screenshot software, why not to choose all-in-one screen capture solution like Action! 3.0. This one application is not only Screenshot Maker but also:
Screen and Game Recorder
Live Streaming Software
Advanced Tool for Screen Drawing
Program for Computer Benchmark and System Monitoring
Download Action! right now to try out all features and options available in this easy yet advanced multi-functional application.
1 Comment
